CQQL Опубликовано: 4 сентября 2011 Рассказать Опубликовано: 4 сентября 2011 я получаю ошибку script, пробуя update библиотеку "Videoteka" on Apple TV2 Please help. Thank you Here is My Log file from XBMC 16:23:48 T:114257920 DEBUG: WaitOnScriptResult - waiting on the Kartina.TV plugin... 16:23:48 T:82153472 DEBUG: ------ Window Init (DialogBusy.xml) ------ 16:23:48 T:110997504 NOTICE: -->Python Interpreter Initialized<-- 16:23:48 T:110997504 DEBUG: Process - The source file to load is /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py 16:23:48 T:110997504 DEBUG: Process - Setting the Python path to /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv:/var/mobile/Library/Preferences/XBMC/addons/script.module.beautifulsoup/lib:/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pil/lib:/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pysqlite/lib:/Applications/XBMC.frappliance/Frameworks:/Applications/XBMC.frappliance/Frameworks/lib/python26.zip:/Applications/XBMC.frappliance/Frameworks/lib/python2.6:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-darwin:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac/lib-scriptpackages:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-tk:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-old:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-dynload:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/site-packages: 16:23:48 T:110997504 DEBUG: Process - Entering source directory /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv 16:23:48 T:110997504 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.kartina.tv" dependent on version 1.0 of the xbmc.python api 16:23:49 T:82153472 INFO: CheckIdle - Closing session to [url="http://xoap.weather.com"]http://xoap.weather.com[/url] (easy=0x6e3c000, multi=0x228eee50) 16:23:49 T:110997504 ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py:22: DeprecationWarning: os.getcwd() currently lies to you so please use addon.getAddonInfo('path') to find the script's root directory and DO NOT make relative path accesses based on the results of 'os.getcwd.' sys.path.append(os.path.join(os.getcwd(), 'resources', 'lib')) 16:23:50 T:114257920 INFO: Loading skin file: DialogProgress.xml 16:23:50 T:114257920 DEBUG: DialogProgress::StartModal called 16:23:50 T:114257920 DEBUG: ------ Window Init (DialogProgress.xml) ------ 16:23:53 T:110997504 ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py:38: DeprecationWarning: os.getcwd() currently lies to you so please use addon.getAddonInfo('path') to find the script's root directory and DO NOT make relative path accesses based on the results of 'os.getcwd.' thumb = os.path.join( os.getcwd(), "icon.png" ) 16:23:53 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:53 T:110997504 NOTICE: [Kartina.TV] Loaded 16:23:53 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:53 T:110997504 NOTICE: [Kartina.TV] parsing params from 16:23:53 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:53 T:110997504 NOTICE: [Kartina.TV] REQUESTING: [url="http://iptv.kartina.tv/api/json/account"]http://iptv.kartina.tv/api/json/account[/url]? 16:23:53 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:53 T:110997504 NOTICE: [Kartina.TV] UA: plugin.video.kartina.tv v1.2.2 (XBMC PRE-11.0 Git:20110903-c1d2bb6 [1280x720]; posix darwin; python 2.6.5) as 1618995 16:23:53 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:53 T:110997504 DEBUG: [Kartina.TV] Got {"account":{"login":1618995,"packet_name":"IPTV Canada","packet_expire":"1315333786"},"servertime":1315167833} 16:23:53 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:53 T:110997504 NOTICE: [Kartina.TV] Saving cookies: /var/mobile/Library/Preferences/XBMC/temp/cookie.iptv.kartina.tv.txt 16:23:53 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:53 T:110997504 NOTICE: [Kartina.TV] REQUESTING: [url="http://iptv.kartina.tv/api/json/settings?var=timeshift"]http://iptv.kartina.tv/api/json/settings?var=timeshift[/url] 16:23:53 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:53 T:110997504 NOTICE: [Kartina.TV] UA: plugin.video.kartina.tv v1.2.2 (XBMC PRE-11.0 Git:20110903-c1d2bb6 [1280x720]; posix darwin; python 2.6.5) as 1618995 16:23:54 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:54 T:110997504 DEBUG: [Kartina.TV] Got {"settings":{"name":"timeshift","value":0,"list":[0,1,2,3,4,8,9,10,11]},"servertime":1315167834} 16:23:54 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:54 T:110997504 NOTICE: [Kartina.TV] Saving cookies: /var/mobile/Library/Preferences/XBMC/temp/cookie.iptv.kartina.tv.txt 16:23:54 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:23:54 T:110997504 NOTICE: [Kartina.TV] mode: None 16:23:54 T:110997504 INFO: Scriptresult: Success 16:23:54 T:114257920 DEBUG: WaitOnScriptResult- plugin returned successfully 16:23:54 T:82153472 DEBUG: Saving fileitems [plugin://plugin.video.kartina.tv] 16:23:54 T:82153472 DEBUG: -- items: 4, sort method: 0, ascending: false 16:23:54 T:804540416 DEBUG: Thread Background Loader start, auto delete: 0 16:23:54 T:110997504 INFO: Python script stopped 16:23:54 T:110997504 DEBUG: Thread XBPyThread 110997504 terminating 16:23:54 T:82153472 DEBUG: waiting for python thread 1 to stop 16:23:54 T:82153472 DEBUG: python thread 1 destructed 16:23:54 T:804540416 DEBUG: Thread Background Loader 804540416 terminating 16:23:54 T:82153472 DEBUG: ------ Window Deinit (DialogProgress.xml) ------ 16:23:54 T:82153472 DEBUG: ------ Window Deinit (DialogBusy.xml) ------ 16:23:57 T:82153472 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.kartina.tv/?mode=VideoLib) 16:23:57 T:82153472 DEBUG: ParentPath = [plugin://plugin.video.kartina.tv] 16:23:57 T:114257920 DEBUG: StartScript - calling plugin Kartina.TV('plugin://plugin.video.kartina.tv/','0','?mode=VideoLib') 16:23:57 T:114257920 INFO: initializing python engine. 16:23:57 T:114257920 DEBUG: new python thread created. id=2 16:23:57 T:114257920 DEBUG: WaitOnScriptResult - waiting on the Kartina.TV plugin... 16:23:57 T:111349760 DEBUG: Thread XBPyThread start, auto delete: 0 16:23:57 T:111349760 DEBUG: Python thread: start processing 16:23:57 T:111349760 NOTICE: -->Python Interpreter Initialized<-- 16:23:57 T:111349760 DEBUG: Process - The source file to load is /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py 16:23:57 T:111349760 ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py:22: DeprecationWarning: os.getcwd() currently lies to you so please use addon.getAddonInfo('path') to find the script's root directory and DO NOT make relative path accesses based on the results of 'os.getcwd.' sys.path.append(os.path.join(os.getcwd(), 'resources', 'lib')) 16:23:57 T:82153472 DEBUG: ------ Window Init (DialogBusy.xml) ------ 16:23:58 T:114257920 INFO: Loading skin file: DialogProgress.xml 16:23:58 T:114257920 DEBUG: DialogProgress::StartModal called 16:23:58 T:114257920 DEBUG: ------ Window Init (DialogProgress.xml) ------ 16:24:00 T:111349760 ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py:38: DeprecationWarning: os.getcwd() currently lies to you so please use addon.getAddonInfo('path') to find the script's root directory and DO NOT make relative path accesses based on the results of 'os.getcwd.' thumb = os.path.join( os.getcwd(), "icon.png" ) 16:24:00 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:00 T:111349760 NOTICE: [Kartina.TV] Loaded 16:24:00 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:00 T:111349760 NOTICE: [Kartina.TV] parsing params from ?mode=VideoLib 16:24:00 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:00 T:111349760 NOTICE: [Kartina.TV] REQUESTING: [url="http://iptv.kartina.tv/api/json/account"]http://iptv.kartina.tv/api/json/account[/url]? 16:24:00 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:00 T:111349760 NOTICE: [Kartina.TV] UA: plugin.video.kartina.tv v1.2.2 (XBMC PRE-11.0 Git:20110903-c1d2bb6 [1280x720]; posix darwin; python 2.6.5) as 1618995 16:24:01 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:01 T:111349760 DEBUG: [Kartina.TV] Got {"account":{"login":1618995,"packet_name":"IPTV Canada","packet_expire":"1315333786"},"servertime":1315167840} 16:24:01 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:01 T:111349760 NOTICE: [Kartina.TV] Saving cookies: /var/mobile/Library/Preferences/XBMC/temp/cookie.iptv.kartina.tv.txt 16:24:01 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:01 T:111349760 NOTICE: [Kartina.TV] REQUESTING: [url="http://iptv.kartina.tv/api/json/settings?var=timeshift"]http://iptv.kartina.tv/api/json/settings?var=timeshift[/url] 16:24:01 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:01 T:111349760 NOTICE: [Kartina.TV] UA: plugin.video.kartina.tv v1.2.2 (XBMC PRE-11.0 Git:20110903-c1d2bb6 [1280x720]; posix darwin; python 2.6.5) as 1618995 16:24:01 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:01 T:111349760 DEBUG: [Kartina.TV] Got {"settings":{"name":"timeshift","value":0,"list":[0,1,2,3,4,8,9,10,11]},"servertime":1315167841} 16:24:01 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:01 T:111349760 NOTICE: [Kartina.TV] Saving cookies: /var/mobile/Library/Preferences/XBMC/temp/cookie.iptv.kartina.tv.txt 16:24:01 T:111349760 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:01 T:111349760 NOTICE: [Kartina.TV] mode: VideoLib 16:24:01 T:114257920 DEBUG: WaitOnScriptResult- plugin returned successfully 16:24:01 T:82153472 DEBUG: Saving fileitems [plugin://plugin.video.kartina.tv/?mode=VideoLib] 16:24:01 T:82153472 DEBUG: -- items: 3, sort method: 0, ascending: false 16:24:01 T:804540416 DEBUG: Thread Background Loader start, auto delete: 0 16:24:01 T:804540416 DEBUG: Thread Background Loader 804540416 terminating 16:24:01 T:111349760 INFO: Scriptresult: Success 16:24:01 T:111349760 INFO: Python script stopped 16:24:01 T:111349760 DEBUG: Thread XBPyThread 111349760 terminating 16:24:01 T:82153472 DEBUG: waiting for python thread 2 to stop 16:24:01 T:82153472 DEBUG: python thread 2 destructed 16:24:01 T:82153472 DEBUG: ------ Window Deinit (DialogProgress.xml) ------ 16:24:01 T:82153472 DEBUG: ------ Window Deinit (DialogBusy.xml) ------ 16:24:03 T:82153472 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.kartina.tv/?mode=VideoLib&do=Play) 16:24:03 T:82153472 DEBUG: ParentPath = [plugin://plugin.video.kartina.tv/?mode=VideoLib] 16:24:03 T:114257920 DEBUG: StartScript - calling plugin Kartina.TV('plugin://plugin.video.kartina.tv/','0','?mode=VideoLib&do=Play') 16:24:03 T:114257920 INFO: initializing python engine. 16:24:03 T:114257920 DEBUG: new python thread created. id=3 16:24:03 T:114257920 DEBUG: WaitOnScriptResult - waiting on the Kartina.TV plugin... 16:24:03 T:110997504 DEBUG: Thread XBPyThread start, auto delete: 0 16:24:03 T:110997504 DEBUG: Python thread: start processing 16:24:04 T:110997504 NOTICE: -->Python Interpreter Initialized<-- 16:24:04 T:110997504 DEBUG: Process - The source file to load is /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py 16:24:04 T:110997504 DEBUG: Process - Setting the Python path to /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv:/var/mobile/Library/Preferences/XBMC/addons/script.module.beautifulsoup/lib:/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pil/lib:/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pysqlite/lib:/Applications/XBMC.frappliance/Frameworks:/Applications/XBMC.frappliance/Frameworks/lib/python26.zip:/Applications/XBMC.frappliance/Frameworks/lib/python2.6:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-darwin:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac/lib-scriptpackages:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-tk:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-old:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-dynload:/Applications/XBMC.frappliance/Frameworks/lib/python2.6/site-packages: 16:24:04 T:110997504 DEBUG: Process - Entering source directory /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv 16:24:04 T:110997504 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.kartina.tv" dependent on version 1.0 of the xbmc.python api 16:24:04 T:110997504 ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py:22: DeprecationWarning: os.getcwd() currently lies to you so please use addon.getAddonInfo('path') to find the script's root directory and DO NOT make relative path accesses based on the results of 'os.getcwd.' sys.path.append(os.path.join(os.getcwd(), 'resources', 'lib')) 16:24:04 T:82153472 DEBUG: ------ Window Init (DialogBusy.xml) ------ 16:24:05 T:114257920 INFO: Loading skin file: DialogProgress.xml 16:24:05 T:114257920 DEBUG: DialogProgress::StartModal called 16:24:05 T:114257920 DEBUG: ------ Window Init (DialogProgress.xml) ------ 16:24:07 T:110997504 ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py:38: DeprecationWarning: os.getcwd() currently lies to you so please use addon.getAddonInfo('path') to find the script's root directory and DO NOT make relative path accesses based on the results of 'os.getcwd.' thumb = os.path.join( os.getcwd(), "icon.png" ) 16:24:07 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:07 T:110997504 NOTICE: [Kartina.TV] Loaded 16:24:07 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:07 T:110997504 NOTICE: [Kartina.TV] parsing params from ?mode=VideoLib&do=Play 16:24:07 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:07 T:110997504 NOTICE: [Kartina.TV] REQUESTING: [url="http://iptv.kartina.tv/api/json/account"]http://iptv.kartina.tv/api/json/account[/url]? 16:24:07 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:07 T:110997504 NOTICE: [Kartina.TV] UA: plugin.video.kartina.tv v1.2.2 (XBMC PRE-11.0 Git:20110903-c1d2bb6 [1280x720]; posix darwin; python 2.6.5) as 1618995 16:24:07 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:07 T:110997504 DEBUG: [Kartina.TV] Got {"account":{"login":1618995,"packet_name":"IPTV Canada","packet_expire":"1315333786"},"servertime":1315167847} 16:24:07 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:07 T:110997504 NOTICE: [Kartina.TV] Saving cookies: /var/mobile/Library/Preferences/XBMC/temp/cookie.iptv.kartina.tv.txt 16:24:07 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:07 T:110997504 NOTICE: [Kartina.TV] REQUESTING: [url="http://iptv.kartina.tv/api/json/settings?var=timeshift"]http://iptv.kartina.tv/api/json/settings?var=timeshift[/url] 16:24:07 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:07 T:110997504 NOTICE: [Kartina.TV] UA: plugin.video.kartina.tv v1.2.2 (XBMC PRE-11.0 Git:20110903-c1d2bb6 [1280x720]; posix darwin; python 2.6.5) as 1618995 16:24:08 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:08 T:110997504 DEBUG: [Kartina.TV] Got {"settings":{"name":"timeshift","value":0,"list":[0,1,2,3,4,8,9,10,11]},"servertime":1315167848} 16:24:08 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:08 T:110997504 NOTICE: [Kartina.TV] Saving cookies: /var/mobile/Library/Preferences/XBMC/temp/cookie.iptv.kartina.tv.txt 16:24:08 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:08 T:110997504 NOTICE: [Kartina.TV] mode: VideoLib 16:24:08 T:114257920 DEBUG: WaitOnScriptResult- plugin returned successfully 16:24:08 T:82153472 DEBUG: Saving fileitems [plugin://plugin.video.kartina.tv/?mode=VideoLib&do=Play] 16:24:08 T:82153472 DEBUG: -- items: 3, sort method: 0, ascending: false 16:24:08 T:804540416 DEBUG: Thread Background Loader start, auto delete: 0 16:24:08 T:804540416 DEBUG: Thread Background Loader 804540416 terminating 16:24:08 T:110997504 INFO: Loading skin file: DialogYesNo.xml 16:24:08 T:82153472 DEBUG: ------ Window Init (DialogYesNo.xml) ------ 16:24:08 T:82153472 DEBUG: ------ Window Deinit (DialogProgress.xml) ------ 16:24:19 T:82153472 DEBUG: SECTION:UnloadDll(libcurl.4.dylib) 16:24:19 T:82153472 DEBUG: Unloading: libcurl.4.dylib 16:24:23 T:82153472 DEBUG: ------ Window Deinit (DialogYesNo.xml) ------ 16:24:23 T:82153472 DEBUG: ------ Window Deinit (DialogBusy.xml) ------ 16:24:23 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:23 T:110997504 NOTICE: Loading sqlite3 as DB engine 16:24:23 T:110997504 INFO: Loading skin file: DialogProgress.xml 16:24:23 T:110997504 DEBUG: DialogProgress::StartModal called 16:24:23 T:110997504 DEBUG: ------ Window Init (DialogProgress.xml) ------ 16:24:23 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:23 T:110997504 NOTICE: [Kartina.TV] REQUESTING: [url="http://iptv.kartina.tv/api/json/vod_list?type=last&nums=1&page=1"]http://iptv.kartina.tv/api/json/vod_list?t...ms=1&page=1[/url] 16:24:23 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:23 T:110997504 NOTICE: [Kartina.TV] UA: plugin.video.kartina.tv v1.2.2 (XBMC PRE-11.0 Git:20110903-c1d2bb6 [1280x720]; posix darwin; python 2.6.5) as 1618995 16:24:24 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:24 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:24 T:110997504 NOTICE: [Kartina.TV] Saving cookies: /var/mobile/Library/Preferences/XBMC/temp/cookie.iptv.kartina.tv.txt 16:24:24 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:24 T:110997504 NOTICE: [Kartina.TV] pagesize set to 1000 to reflect "all" param 16:24:24 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:24 T:110997504 NOTICE: [Kartina.TV] REQUESTING: [url="http://iptv.kartina.tv/api/json/vod_list?type=last&nums=1000&page=1"]http://iptv.kartina.tv/api/json/vod_list?t...1000&page=1[/url] 16:24:24 T:110997504 WARNING: 'xbmc.output()' is depreciated and will be removed in future releases, please use 'xbmc.log()' instead 16:24:44 T:110997504 INFO: -->Python script returned the following error<-- 16:24:44 T:110997504 ERROR: Error Type: <class 'sqlite3.OperationalError'> 16:24:44 T:110997504 ERROR: Error Contents: no such table: path 16:24:44 T:110997504 ERROR: Traceback (most recent call last): File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py", line 873, in <module> VideoLib(PLUGIN_CORE, params) File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py", line 722, in VideoLib MovieLib(plugin, 'Update') File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/default.py", line 771, in MovieLib if m.vdbMovieByPathAndTrailer(sys.argv[0], info): File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/resources/lib/movielib.py", line 384, in vdbMovieByPathAndTrailer pid = self._vdbGetPathId(path) File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.kartina.tv/resources/lib/movielib.py", line 221, in _vdbGetPathId self.db.execute("SELECT idPath FROM path WHERE strPath=?", (path,)) OperationalError: no such table: path 16:24:44 T:110997504 INFO: -->End of Python script error report<-- 16:24:44 T:82153472 DEBUG: ------ Window Init (DialogKaiToast.xml) ------ 16:24:44 T:82153472 DEBUG: ------ Window Deinit (DialogProgress.xml) ------ 16:24:44 T:110997504 INFO: Python script stopped 16:24:44 T:110997504 DEBUG: Thread XBPyThread 110997504 terminating 16:24:45 T:82153472 DEBUG: waiting for python thread 3 to stop 16:24:45 T:82153472 DEBUG: python thread 3 destructed 16:24:50 T:82153472 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------ 16:24:55 T:82153472 INFO: Python, unloading python shared library because no scripts are running anymore Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 5 сентября 2011 Рассказать Опубликовано: 5 сентября 2011 я получаю ошибку script, пробуя update библиотеку "Videoteka" on Apple TV2 Please help. плиз чек зе превиоус пейдж, бикоз это уже обсуждалось и не однократно. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Ruslan Опубликовано: 5 сентября 2011 Рассказать Опубликовано: 5 сентября 2011 Privet Evgenij, Na XBMC 11 tema po videoteke prodvigaetsa ?! Spasibo Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 5 сентября 2011 Рассказать Опубликовано: 5 сентября 2011 нет. не продвигается xbmc 11 - не продвигается тема видеотеки. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Dmitri0208 Опубликовано: 5 сентября 2011 Рассказать Опубликовано: 5 сентября 2011 нет. не продвигается xbmc 11 - не продвигается тема видеотеки. Женя привет ! Есть вопрос такой, на приставке в списке каналов есть 9 канал - Израиль +, а в Драхме его нет. Приставка и твой плагин для Драхмы разве отличаются в принципе ? Может подкинешь идею - жена достала уже с этим каналом Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 6 сентября 2011 Рассказать Опубликовано: 6 сентября 2011 Дима, привет вот какая есть идея - попробуй внимательнее полистать список каналов Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Dmitri0208 Опубликовано: 6 сентября 2011 Рассказать Опубликовано: 6 сентября 2011 Дима, привет вот какая есть идея - попробуй внимательнее полистать список каналов Жень, извини, конечно - но израиль + нет в списке каналов, как бы внимательно я не смотрел :-) Может это как то связано , что я в Израиле живу и израильский сервер вещания.Хотя вряд ли. Кстати на сайтах и у нас и в германии, тоже нет этого канала в списке. А в Дюне есть ! Просто фантастика. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 6 сентября 2011 Рассказать Опубликовано: 6 сентября 2011 Дим, о существовании этого канала я вообще впервые услышал от тебя вчера.. если через онлайн-плеер смотреть канал есть? Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 6 сентября 2011 Рассказать Опубликовано: 6 сентября 2011 Дим, я вот тут не поленился и пролистал список каналов. Между "Библейским маяком" и "1+1" есть некий "Израиль+". Это таки оно? Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
stormillo Опубликовано: 7 сентября 2011 Рассказать Опубликовано: 7 сентября 2011 Евгенй добого времени суток, и еще раз спасибо за плагин. Появилась проблема которую ни как не могу решить. Ни стого ни ссего при запуске пишет . Пробовал переустановить, не помогает. Также не работает ни один скрипт на XBMC 10.1 Apple TV Gen 1. Log File.... 21:33:47 T:2684407808 M: 40472576 NOTICE: ----------------------------------------------------------------------- 21:33:47 T:2684407808 M: 40435712 NOTICE: Starting XBMC, Platform: Mac OS X (8.8.2 i386). Built on Mar 9 2011 (Git:e9e9099) 21:33:47 T:2684407808 M: 40435712 NOTICE: special://xbmc/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC 21:33:47 T:2684407808 M: 40439808 NOTICE: special://xbmcbin/ is mapped to: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC 21:33:47 T:2684407808 M: 40435712 NOTICE: special://masterprofile/ is mapped to: /Users/frontrow/Library/Application Support/XBMC/userdata 21:33:47 T:2684407808 M: 40439808 NOTICE: special://home/ is mapped to: /Users/frontrow/Library/Application Support/XBMC 21:33:47 T:2684407808 M: 40435712 NOTICE: special://temp/ is mapped to: /Users/frontrow/.xbmc/temp 21:33:47 T:2684407808 M: 40464384 NOTICE: The executable running is: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/MacOS/XBMC 21:33:47 T:2684407808 M: 40460288 NOTICE: Log File is located: /Users/frontrow/Library/Logs/xbmc.log 21:33:47 T:2684407808 M: 40464384 NOTICE: ----------------------------------------------------------------------- 21:33:47 T:2684407808 M: 40464384 NOTICE: Setup SDL 21:33:48 T:2684407808 M: 39342080 NOTICE: load settings... 21:33:48 T:2684407808 M: 39194624 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found 21:33:48 T:2684407808 M: 39190528 NOTICE: special://profile/ is mapped to: special://masterprofile/ 21:33:48 T:2684407808 M: 39190528 NOTICE: loading special://masterprofile/guisettings.xml 21:33:48 T:2684407808 M: 39165952 NOTICE: Getting hardware information now... 21:33:48 T:2684407808 M: 39165952 NOTICE: Checking resolution 12 21:33:48 T:2684407808 M: 39165952 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml. 21:33:48 T:2684407808 M: 39145472 NOTICE: Loaded playercorefactory configuration 21:33:48 T:2684407808 M: 39161856 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml. 21:33:48 T:2684407808 M: 39161856 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping. 21:33:48 T:2684407808 M: 39157760 NOTICE: Loaded advancedsettings.xml from special://profile/advancedsettings.xml 21:33:48 T:2684407808 M: 39157760 NOTICE: Contents of special://profile/advancedsettings.xml are... <advancedsettings> <skiploopfilter>8</skiploopfilter> </advancedsettings> 21:33:48 T:2684407808 M: 39157760 NOTICE: Getting hardware information now... 21:33:48 T:2684407808 M: 39157760 NOTICE: Checking resolution 12 21:33:48 T:2684407808 M: 39157760 NOTICE: Default DVD Player: dvdplayer 21:33:48 T:2684407808 M: 39157760 NOTICE: Default Video Player: dvdplayer 21:33:48 T:2684407808 M: 39157760 NOTICE: Default Audio Player: paplayer 21:33:48 T:2684407808 M: 39157760 NOTICE: Loading media sources from special://masterprofile/sources.xml 21:33:50 T:2684407808 M: 30007296 NOTICE: GL_VENDOR = NVIDIA Corporation 21:33:50 T:2684407808 M: 30007296 NOTICE: GL_RENDERER = NVIDIA GeForce Go 7300 OpenGL Engine 21:33:50 T:2684407808 M: 30003200 NOTICE: GL_VERSION = 1.5 NVIDIA-1.4.60 21:33:50 T:2684407808 M: 30007296 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.10 21:33:50 T:2684407808 M: 30003200 NOTICE: GL_EXTENSIONS = GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_shading_language_100 GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_EXT_compiled_vertex_array GL_EXT_framebuffer_object GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_APPLE_pixel_buffer GL_NV_point_sprite GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_blend_square GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_fog_distance GL_NV_depth_clamp GL_NV_multisample_filter_hint GL_NV_fragment_program_option GL_NV_vertex_program2_option GL_ATI_texture_mirror_once GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod 21:33:51 T:2684407808 M: 25722880 NOTICE: start dvd mediatype detection 21:33:51 T:2684407808 M: 25542656 NOTICE: initializing playlistplayer 21:33:51 T:2684407808 M: 25542656 NOTICE: DONE initializing playlistplayer 21:33:53 T:2684407808 M: 14667776 NOTICE: initialize done 21:33:53 T:2684407808 M: 14671872 NOTICE: Running the application... 21:33:53 T:2684407808 M: 14663680 NOTICE: ES: Starting event server 21:33:53 T:51842048 M: 14659584 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777 21:33:53 T:51842048 M: 14655488 NOTICE: UDP: Listening on port 9777 21:33:53 T:2684407808 M: 14643200 NOTICE: starting zeroconf publishing 21:34:26 T:52823552 M: 4108288 NOTICE: -->Python Interpreter Initialized<-- 21:34:31 T:52823552 M: 3493888 NOTICE: [KartinaTV] module json is not available. using demjson 21:34:31 T:52823552 M: 3252224 NOTICE: [Kartina.TV] Loaded 21:34:31 T:52823552 M: 3313664 NOTICE: [Kartina.TV] parsing params from 21:34:31 T:52823552 M: 3297280 ERROR: Error Type: cookielib.LoadError 21:34:31 T:52823552 M: 3313664 ERROR: Error Contents: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:34:31 T:52823552 M: 3207168 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/default.py", line 833, in ? PLUGIN_CORE = iptv.kartina(USERNAME, USERPASS, PLUGIN_ID, SID, SID_NAME) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/resources/lib/iptv.py", line 125, in __init__ COOKIEJAR.load(COOKIEFILE) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/cookielib.py", line 1723, in load self._really_load(f, filename, ignore_discard, ignore_expires) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/_LWPCookieJar.py", line 96, in _really_load raise LoadError(msg) LoadError: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:34:31 T:2684407808 M: 3362816 ERROR: GetDirectory - Error getting plugin://plugin.video.kartina.tv/ 21:34:31 T:2684407808 M: 3362816 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kartina.tv/) failed 21:34:47 T:52731392 M: 4825088 NOTICE: -->Python Interpreter Initialized<-- 21:34:52 T:52731392 M: 3850240 NOTICE: initial info - rtc_uri = [scgi://127.0.0.1:5000] 21:34:52 T:52731392 M: 3850240 NOTICE: initial info - rtc_select = [true] 21:34:58 T:52641792 M: 8450048 NOTICE: -->Python Interpreter Initialized<-- 21:35:02 T:52641792 M: 7860224 NOTICE: initial info - rtc_uri = [scgi://127.0.0.1:5000] 21:35:02 T:52641792 M: 7860224 NOTICE: initial info - rtc_select = [true] 21:35:02 T:52641792 M: 7860224 NOTICE: === def filmsbrowse({'fields_mask': '63', 'href': '%2Ffilms%2Fbrowse', 'limit': '50', 'mode': 'filmsbrowse', 'offset': '0', 'type': 'movie'}): === 21:35:02 T:52641792 M: 7860224 NOTICE: KBREQUEST -> URL = [/films/browse?limit=50&offset=0&fields_mask=63&type=movie] 21:35:02 T:52641792 M: 7860224 NOTICE: KBREQUEST -> post_params = [None] 21:35:18 T:52641792 M: 7598080 ERROR: Error Type: socket.timeout 21:35:18 T:52641792 M: 7598080 ERROR: Error Contents: timed out 21:35:18 T:52641792 M: 7299072 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/default.py", line 28, in ? kbxbmc.addon_main() File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/resources/lib/kbxbmc.py", line 865, in addon_main if func: func(params) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/resources/lib/kbxbmc.py", line 398, in filmsbrowse http = kbutils.KBREQUEST('%s?%s'%(href,urllib.urlencode(GL))) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/resources/lib/kbutils.py", line 107, in KBREQUEST response = connection.getresponse() File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/httplib.py", line 866, in getresponse response.begin() File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/httplib.py", line 336, in begin version, status, reason = self._read_status() File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/httplib.py", line 294, in _read_status line = self.fp.readline() File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/socket.py", line 317, in readline data = recv(1) timeout: timed out 21:35:18 T:2684407808 M: 6971392 ERROR: GetDirectory - Error getting plugin://plugin.video.kinobaza.tv/?mode=filmsbrowse&fields_mask=63&limit=50&offset=0&type=movie&href=%2Ffilms%2Fbrowse 21:35:18 T:2684407808 M: 7016448 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kinobaza.tv/?mode=filmsbrowse&fields_mask=63&limit=50&offset=0&type=movie&href=%2Ffilms%2Fbrowse) failed 21:35:34 T:53039616 M: 7188480 NOTICE: -->Python Interpreter Initialized<-- 21:35:38 T:53039616 M: 6656000 NOTICE: initial info - rtc_uri = [scgi://127.0.0.1:5000] 21:35:38 T:53039616 M: 6651904 NOTICE: initial info - rtc_select = [true] 21:35:38 T:53039616 M: 6651904 NOTICE: === def rtcshowdl({'mode': 'rtcshowdl'}): === 21:35:38 T:2684407808 M: 6504448 ERROR: GetDirectory - Error getting plugin://plugin.video.kinobaza.tv/?mode=rtcshowdl 21:35:38 T:2684407808 M: 6504448 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kinobaza.tv/?mode=rtcshowdl) failed 21:35:47 T:52911104 M: 7331840 NOTICE: -->Python Interpreter Initialized<-- 21:35:51 T:52911104 M: 6750208 NOTICE: initial info - rtc_uri = [scgi://127.0.0.1:5000] 21:35:51 T:52911104 M: 6750208 NOTICE: initial info - rtc_select = [true] 21:36:19 T:52911104 M: 5124096 NOTICE: === def filmsbrowse({'fields_mask': '63', 'href': '%2Ffilms%2Fsearch', 'limit': '50', 'mode': 'filmsbrowse', 'offset': '0', 'query': 'horror+', 'type': 'movie'}): === 21:36:19 T:52911104 M: 5144576 NOTICE: KBREQUEST -> URL = [/films/search?limit=50&offset=0&fields_mask=63&query=horror+&type=movie] 21:36:19 T:52911104 M: 5144576 NOTICE: KBREQUEST -> post_params = [None] 21:36:35 T:52911104 M: 5099520 ERROR: Error Type: socket.timeout 21:36:35 T:52911104 M: 5095424 ERROR: Error Contents: timed out 21:36:35 T:52911104 M: 5062656 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/default.py", line 28, in ? kbxbmc.addon_main() File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/resources/lib/kbxbmc.py", line 865, in addon_main if func: func(params) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/resources/lib/kbxbmc.py", line 328, in filmssearch filmsbrowse(params) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/resources/lib/kbxbmc.py", line 398, in filmsbrowse http = kbutils.KBREQUEST('%s?%s'%(href,urllib.urlencode(GL))) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kinobaza.tv/resources/lib/kbutils.py", line 107, in KBREQUEST response = connection.getresponse() File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/httplib.py", line 866, in getresponse response.begin() File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/httplib.py", line 336, in begin version, status, reason = self._read_status() File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/httplib.py", line 294, in _read_status line = self.fp.readline() File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/socket.py", line 317, in readline data = recv(1) timeout: timed out 21:36:35 T:2684407808 M: 4763648 ERROR: GetDirectory - Error getting plugin://plugin.video.kinobaza.tv/?mode=filmssearch&fields_mask=63&limit=50&offset=0&type=movie&href=%2Ffilms%2Fsearch 21:36:35 T:2684407808 M: 4784128 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kinobaza.tv/?mode=filmssearch&fields_mask=63&limit=50&offset=0&type=movie&href=%2Ffilms%2Fsearch) failed 21:37:37 T:53497856 M: 17448960 NOTICE: -->Python Interpreter Initialized<-- 21:37:41 T:53497856 M: 16408576 NOTICE: [KartinaTV] module json is not available. using demjson 21:37:41 T:53497856 M: 16306176 NOTICE: [Kartina.TV] Loaded 21:37:41 T:53497856 M: 16306176 NOTICE: [Kartina.TV] parsing params from 21:37:41 T:53497856 M: 16306176 ERROR: Error Type: cookielib.LoadError 21:37:41 T:53497856 M: 16306176 ERROR: Error Contents: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:37:41 T:53497856 M: 16306176 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/default.py", line 833, in ? PLUGIN_CORE = iptv.kartina(USERNAME, USERPASS, PLUGIN_ID, SID, SID_NAME) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/resources/lib/iptv.py", line 125, in __init__ COOKIEJAR.load(COOKIEFILE) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/cookielib.py", line 1723, in load self._really_load(f, filename, ignore_discard, ignore_expires) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/_LWPCookieJar.py", line 96, in _really_load raise LoadError(msg) LoadError: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:37:41 T:2684407808 M: 16179200 ERROR: GetDirectory - Error getting plugin://plugin.video.kartina.tv/ 21:37:41 T:2684407808 M: 16179200 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kartina.tv/) failed 21:37:48 T:51727360 M: 17022976 NOTICE: -->Python Interpreter Initialized<-- 21:37:52 T:51727360 M: 15896576 NOTICE: [KartinaTV] module json is not available. using demjson 21:37:52 T:51727360 M: 15896576 NOTICE: [Kartina.TV] Loaded 21:37:52 T:51727360 M: 15896576 NOTICE: [Kartina.TV] parsing params from 21:37:52 T:51727360 M: 15896576 ERROR: Error Type: cookielib.LoadError 21:37:52 T:51727360 M: 15896576 ERROR: Error Contents: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:37:52 T:51727360 M: 15896576 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/default.py", line 833, in ? PLUGIN_CORE = iptv.kartina(USERNAME, USERPASS, PLUGIN_ID, SID, SID_NAME) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/resources/lib/iptv.py", line 125, in __init__ COOKIEJAR.load(COOKIEFILE) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/cookielib.py", line 1723, in load self._really_load(f, filename, ignore_discard, ignore_expires) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/_LWPCookieJar.py", line 96, in _really_load raise LoadError(msg) LoadError: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:37:52 T:2684407808 M: 15757312 ERROR: GetDirectory - Error getting plugin://plugin.video.kartina.tv/ 21:37:52 T:2684407808 M: 15757312 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kartina.tv/) failed 21:38:01 T:53826048 M: 16752640 NOTICE: -->Python Interpreter Initialized<-- 21:38:05 T:53826048 M: 15986688 NOTICE: [KartinaTV] module json is not available. using demjson 21:38:05 T:53826048 M: 15978496 NOTICE: [Kartina.TV] Loaded 21:38:05 T:53826048 M: 15978496 NOTICE: [Kartina.TV] parsing params from 21:38:05 T:53826048 M: 15978496 ERROR: Error Type: cookielib.LoadError 21:38:05 T:53826048 M: 15978496 ERROR: Error Contents: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:38:05 T:53826048 M: 15978496 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/default.py", line 833, in ? PLUGIN_CORE = iptv.kartina(USERNAME, USERPASS, PLUGIN_ID, SID, SID_NAME) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/resources/lib/iptv.py", line 125, in __init__ COOKIEJAR.load(COOKIEFILE) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/cookielib.py", line 1723, in load self._really_load(f, filename, ignore_discard, ignore_expires) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/_LWPCookieJar.py", line 96, in _really_load raise LoadError(msg) LoadError: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:38:05 T:2684407808 M: 15839232 ERROR: GetDirectory - Error getting plugin://plugin.video.kartina.tv/ 21:38:05 T:2684407808 M: 15839232 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kartina.tv/) failed 21:38:16 T:52441600 M: 17707008 WARNING: CreateLoader - Unsupported protocol(newsmartplaylist) in newsmartplaylist://movie.tbn/ 21:38:16 T:52441600 M: 17178624 WARNING: Create - Unsupported protocol(newsmartplaylist) in newsmartplaylist:// 21:38:25 T:54035968 M: 13664256 NOTICE: -->Python Interpreter Initialized<-- 21:38:28 T:54035968 M: 12533760 NOTICE: [KartinaTV] module json is not available. using demjson 21:38:28 T:54035968 M: 12345344 NOTICE: [Kartina.TV] Loaded 21:38:28 T:54035968 M: 12345344 NOTICE: [Kartina.TV] parsing params from ?mode=WatchVOD&vod=2801&title=Winx Club: Волшебное приключение 21:38:28 T:54035968 M: 12304384 ERROR: Error Type: cookielib.LoadError 21:38:28 T:54035968 M: 12304384 ERROR: Error Contents: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:38:29 T:54035968 M: 12271616 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/default.py", line 833, in ? PLUGIN_CORE = iptv.kartina(USERNAME, USERPASS, PLUGIN_ID, SID, SID_NAME) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/resources/lib/iptv.py", line 125, in __init__ COOKIEJAR.load(COOKIEFILE) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/cookielib.py", line 1723, in load self._really_load(f, filename, ignore_discard, ignore_expires) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/_LWPCookieJar.py", line 96, in _really_load raise LoadError(msg) LoadError: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 21:38:29 T:2684407808 M: 12292096 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.kartina.tv/?mode=WatchVOD&vod=2801&title=Winx Club: Волшебное приключение ] 21:38:32 T:54297600 M: 11681792 WARNING: CreateLoader - Unsupported protocol(newsmartplaylist) in newsmartplaylist://movie.tbn/ 21:38:32 T:54297600 M: 11681792 WARNING: Create - Unsupported protocol(newsmartplaylist) in newsmartplaylist:// 21:41:25 T:51842048 M: 32309248 NOTICE: ES: Client from 127.0.0.1 timed out 22:18:41 T:2684407808 M: 35028992 NOTICE: ES: Starting event server 22:18:53 T:2684407808 M: 34705408 NOTICE: Enabled debug logging due to GUI setting. Level 2. 22:19:02 T:2684407808 M: 34766848 NOTICE: Disabled debug logging due to GUI setting. Level 0. 22:19:04 T:2684407808 M: 34807808 NOTICE: ES: Starting event server 22:19:50 T:54099456 M: 35831808 NOTICE: Previous line repeats 2 times. 22:19:50 T:54099456 M: 35831808 NOTICE: -->Python Interpreter Initialized<-- 22:19:54 T:54099456 M: 34516992 NOTICE: [KartinaTV] module json is not available. using demjson 22:19:55 T:54099456 M: 34267136 NOTICE: [Kartina.TV] Loaded 22:19:55 T:54099456 M: 34349056 NOTICE: [Kartina.TV] parsing params from 22:19:55 T:54099456 M: 34332672 ERROR: Error Type: cookielib.LoadError 22:19:55 T:54099456 M: 34349056 ERROR: Error Contents: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 22:19:55 T:54099456 M: 34234368 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/default.py", line 833, in ? PLUGIN_CORE = iptv.kartina(USERNAME, USERPASS, PLUGIN_ID, SID, SID_NAME) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/resources/lib/iptv.py", line 125, in __init__ COOKIEJAR.load(COOKIEFILE) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/cookielib.py", line 1723, in load self._really_load(f, filename, ignore_discard, ignore_expires) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/_LWPCookieJar.py", line 96, in _really_load raise LoadError(msg) LoadError: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 22:19:55 T:2684407808 M: 33976320 ERROR: GetDirectory - Error getting plugin://plugin.video.kartina.tv/ 22:19:55 T:2684407808 M: 33976320 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kartina.tv/) failed 22:20:06 T:52160512 M: 29368320 WARNING: CreateLoader - Unsupported protocol(addons) in addons://more/executable.tbn 22:21:12 T:52148736 M: 32382976 WARNING: FillBuffer: curl failed with code 22 22:21:12 T:52148736 M: 32378880 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream. 22:21:12 T:52148736 M: 32378880 ERROR: GetDirectory - Unable to get http directory 22:21:12 T:52148736 M: 32378880 ERROR: GetDirectory - Error getting http://seppius-xbmc-repo.googlecode.com/sv....tv/../ 22:21:14 T:52148736 M: 30920704 WARNING: FillBuffer: curl failed with code 22 22:21:14 T:52148736 M: 30924800 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream. 22:21:14 T:52148736 M: 30920704 ERROR: GetDirectory - Unable to get http directory 22:21:14 T:52148736 M: 30924800 ERROR: GetDirectory - Error getting http://seppius-xbmc-repo.googlecode.com/sv...ces/../ 22:21:15 T:52148736 M: 32342016 WARNING: FillBuffer: curl failed with code 22 22:21:15 T:52148736 M: 32337920 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream. 22:21:15 T:52148736 M: 32337920 ERROR: GetDirectory - Unable to get http directory 22:21:15 T:52148736 M: 32337920 ERROR: GetDirectory - Error getting http://seppius-xbmc-repo.googlecode.com/sv...ons/../ 22:21:16 T:52148736 M: 32337920 WARNING: FillBuffer: curl failed with code 22 22:21:16 T:52148736 M: 32337920 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream. 22:21:16 T:52148736 M: 32337920 ERROR: GetDirectory - Unable to get http directory 22:21:16 T:52148736 M: 32337920 ERROR: GetDirectory - Error getting http://seppius-xbmc-repo.googlecode.com/sv...age/../ 22:21:17 T:52148736 M: 32329728 WARNING: FillBuffer: curl failed with code 22 22:21:17 T:52148736 M: 32329728 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream. 22:21:17 T:52148736 M: 32329728 ERROR: GetDirectory - Unable to get http directory 22:21:17 T:52148736 M: 32329728 ERROR: GetDirectory - Error getting http://seppius-xbmc-repo.googlecode.com/sv...ish/../ 22:21:18 T:52148736 M: 32329728 WARNING: FillBuffer: curl failed with code 22 22:21:18 T:52148736 M: 32329728 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream. 22:21:18 T:52148736 M: 32329728 ERROR: GetDirectory - Unable to get http directory 22:21:18 T:52148736 M: 32329728 ERROR: GetDirectory - Error getting http://seppius-xbmc-repo.googlecode.com/sv...ian/../ 22:21:19 T:52148736 M: 32321536 WARNING: FillBuffer: curl failed with code 22 22:21:19 T:52148736 M: 32321536 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream. 22:21:19 T:52148736 M: 32321536 ERROR: GetDirectory - Unable to get http directory 22:21:19 T:52148736 M: 32321536 ERROR: GetDirectory - Error getting http://seppius-xbmc-repo.googlecode.com/sv...lib/../ 22:21:35 T:52160512 M: 31346688 WARNING: CreateLoader - Unsupported protocol(addons) in addons://more/executable.tbn 22:21:43 T:54517760 M: 26890240 NOTICE: -->Python Interpreter Initialized<-- 22:21:48 T:54517760 M: 25788416 NOTICE: [KartinaTV] module json is not available. using demjson 22:21:52 T:54517760 M: 23986176 NOTICE: [Kartina.TV] Loaded 22:21:52 T:54517760 M: 23990272 NOTICE: [Kartina.TV] parsing params from 22:21:52 T:54517760 M: 23986176 ERROR: Error Type: cookielib.LoadError 22:21:52 T:54517760 M: 23990272 ERROR: Error Contents: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 22:21:52 T:54517760 M: 23986176 ERROR: Traceback (most recent call last): File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/default.py", line 833, in ? PLUGIN_CORE = iptv.kartina(USERNAME, USERPASS, PLUGIN_ID, SID, SID_NAME) File "/Users/frontrow/Library/Application Support/XBMC/addons/plugin.video.kartina.tv/resources/lib/iptv.py", line 125, in __init__ COOKIEJAR.load(COOKIEFILE) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/cookielib.py", line 1723, in load self._really_load(f, filename, ignore_discard, ignore_expires) File "/mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/python/Lib/_LWPCookieJar.py", line 96, in _really_load raise LoadError(msg) LoadError: /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt does not seem to contain cookies 22:21:52 T:2684407808 M: 23707648 ERROR: GetDirectory - Error getting plugin://plugin.video.kartina.tv/ 22:21:52 T:2684407808 M: 23703552 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.kartina.tv/) failed 22:22:00 T:2684407808 M: 29302784 NOTICE: Storing total System Uptime 22:22:00 T:2684407808 M: 29319168 NOTICE: Saving settings 22:22:00 T:2684407808 M: 29310976 NOTICE: stop all 22:22:00 T:2684407808 M: 29327360 NOTICE: ES: Stopping event server 22:22:00 T:2684407808 M: 29302784 NOTICE: stopping zeroconf publishing 22:22:01 T:51842048 M: 29392896 NOTICE: ES: UDP Event server stopped 22:22:01 T:2684407808 M: 29491200 NOTICE: stop dvd detect media 22:22:01 T:2684407808 M: 29450240 NOTICE: stop sap announcement listener 22:22:01 T:2684407808 M: 29446144 NOTICE: clean cached files! 22:22:01 T:2684407808 M: 29450240 NOTICE: unload skin 22:22:01 T:2684407808 M: 38752256 NOTICE: stop python 22:22:01 T:2684407808 M: 48533504 NOTICE: stopped 22:22:01 T:2684407808 M: 48533504 NOTICE: destroy 22:22:01 T:2684407808 M: 48586752 NOTICE: unload sections Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 7 сентября 2011 Рассказать Опубликовано: 7 сентября 2011 stormillo, попробуйте удалить файл /Users/frontrow/.xbmc/temp/cookie.iptv.kartina.tv.txt Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
stormillo Опубликовано: 7 сентября 2011 Рассказать Опубликовано: 7 сентября 2011 Евгений спасибо... Да это были те самые куки, которые и мешали работе... Сейчас все заработало. Я понял что за проблема, но не понял какие именно куки, удалил не те )), но устройство работает исправно. Еще раз спасибо. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
laskas Опубликовано: 7 сентября 2011 Рассказать Опубликовано: 7 сентября 2011 privet vsem, hociu zakazat na god Kartinu. imeju htcp centr, hociu smotret cerez XBMC,est neskolko voprosov, kakaja versija XBMC lucsaja, ctoby Videoteka rabotala? Kakije problemy est v XBMC s Kartinai (esli oni konecno est) ? S uvazenijem spasibo za otvety Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 7 сентября 2011 Рассказать Опубликовано: 7 сентября 2011 laskas, для видеотеки лучше версия 10.х Dharma, о чем упоминается минимум по разу на каждой из страниц обсуждения на счет пробы как работает и проблем - возьмите абонемент на месяц и попробуйте. потом возмете на год.. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
BASARAB Опубликовано: 7 сентября 2011 Рассказать Опубликовано: 7 сентября 2011 Ustanovil nedeliu nazad na atv2. O4eni klassno, spasibo bolshoe za plagin Eugene!! Teperi moi druzia nachinaiut Apple tv pokupati lol Budu jdati xbmc 11 chtob videoteka zarabotala i mojet pekliuchenie kanalov budet pobistree. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
stormillo Опубликовано: 7 сентября 2011 Рассказать Опубликовано: 7 сентября 2011 Ustanovil nedeliu nazad na atv2. O4eni klassno, spasibo bolshoe za plagin Eugene!! Teperi moi druzia nachinaiut Apple tv pokupati lol Budu jdati xbmc 11 chtob videoteka zarabotala i mojet pekliuchenie kanalov budet pobistree. И скорость переклйчения каналов, на секундочку, и на оригенальной коробке (официальной от картины), тоже очень медленное. У меня даже на АТВ гораздо быстрее. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
laskas Опубликовано: 8 сентября 2011 Рассказать Опубликовано: 8 сентября 2011 spasibo za otvety za skolko sekund na xbmc otkryvajetsa kanaly, bystreje cem na originalnoj karobke? Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
BASARAB Опубликовано: 16 сентября 2011 Рассказать Опубликовано: 16 сентября 2011 ATV2 Quartz tema, net option Big List. Ne znaete kak dobaviti sluchaino? Ikonki riadom s kanalami bolshie i net chetkosti Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 17 сентября 2011 Рассказать Опубликовано: 17 сентября 2011 ATV2 Quartz tema, net option Big List. Ne znaete kak dobaviti sluchaino? впервые слышу про эту тему. вы пробовали обращаться к автору темы и спрашивать у него? Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
BASARAB Опубликовано: 18 сентября 2011 Рассказать Опубликовано: 18 сентября 2011 ATV2 Quartz tema, net option Big List. Ne znaete kak dobaviti sluchaino? впервые слышу про эту тему. вы пробовали обращаться к автору темы и спрашивать у него? Da, neskolko dnei nazad. Quartz ochen ochen bistro rabotaet na Atv2. Obsujdenie zdesi http://forum.xbmc.org/showthread.php?p=891044#post891044, mojet vi avtoru podskajete chto nibudi. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
bigdude Опубликовано: 3 октября 2011 Рассказать Опубликовано: 3 октября 2011 добрый день Женя. у меня appl tv 2, seppius 1.0.0, картина 1.2.2, xbmc add-on 2.01. я вегда имею одну и туже проблему, после начала просмотра любого канала через 5-10 минут ве скидывается и выходит в главное меню appl tv 2. что делать, как мне избавиться от этого? зарание благадарю. Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 3 октября 2011 Рассказать Опубликовано: 3 октября 2011 bigdude, у меня две версии: 1) проблема с xbmc (нужен xbmc.log, желательно в pastebin.com) 2) проблема с atv2 (например находит обновление системы, нужно лечить при помощи мантры "apt-get install com.nito.updatebegone") Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
ccobka Опубликовано: 9 октября 2011 Рассказать Опубликовано: 9 октября 2011 Eugene u menia tut problema poyavilas na Mac Mini s Lion OSX. Kazdii raz starayus zapustit Kartinu comp vidaet "script failed plugin video kartina.tv" Ya suda zakinul Log File http://pastebin.com/42Xq6YcU Esli budet vozmozhnost' dai znat' chto pochemu Kartina nerabotaet. Ogromno blagodaren Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
Eugene Опубликовано: 9 октября 2011 Рассказать Опубликовано: 9 октября 2011 лог не показывает ошибки в плагине. так что: 1) пробуем переключиться на страндартный скин 2) если не помогает, пробуем отключить все остальные плагины Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
ccobka Опубликовано: 9 октября 2011 Рассказать Опубликовано: 9 октября 2011 лог не показывает ошибки в плагине. так что: 1) пробуем переключиться на страндартный скин 2) если не помогает, пробуем отключить все остальные плагины Perekluchil na standartnii skin rezultat totzhe. Pereinstaliroval XBMC tozhe samii error. Chto mozhno ische poprobovat'? Цитата Ссылка на комментарий Поделиться на других сайтах More sharing options...
