sciagent Опубликовано: 27 декабря 2012 Жалоба Рассказать Опубликовано: 27 декабря 2012 (изменено) Dune HD Base 3D Description Dune HD Base 3D is the most affordable universal solution for Full HD video and audio playback as well as IPTV and VOD streams via the new Dune HD Portal. Supporting most all digital audio and video formats, codecs and file containers, including all modern 3D video standards such as MVC, SBS and Top/Bottom, audiophile uncompressed HD audio with high resolutions up to 24 bit /192 kHz, the Dune HD Base 3D sets an entirely new standard. Like previous models in the Dune HD Base range, the all new Base 3D is equipped with an internal 3.5” SATA HDD bay with hot swap function. Key Features 3D Video Format Support: Decodes wide variety of 3D Video formats, including MVC, SBS, Top/Bottom. HDD Player: Plays content from any HDD (internal, NAS or USB) Network Player: Connect Dune HD player to a local network and play content directly from PC or NAS via UPnP, SMB, or NFS. MKV Player: Playback HD and SD video in MKV containers and other modern video file formats, including top quality HD video with very high bit-rates > 50Mbp/s. HD audio: enjoy top-quality audio tracks (Dolby True HD, DTS HD Master Audio, LPCM, FLAC). USB Ports: Conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices without a USB hub. HDD Rack Option with Hot Swap Function: Easily and quickly insert and exchange internal 3.5’’ SATA HDDs for nearly unlimited storage capacity expansion. HDMI 1.4: Ensures broad compatibility to the very latest 3D TV’s, displays and projectors. Full Range of A/V Connectors: S/PDIF Optical and Coaxial Audio outputs, Analog Stereo Audio output, HDMI output, Component and Composite Video outputs. Extended support for Dolby True HD and DTS HD Master Audio: output bitstream (up to 7.1 channels) or decode to LPCM (up to 7.1 channels) for maximum flexibility when connecting audio equipment, and for extended support of advanced playback features (such as Picture-in-Picture). High-Quality Music Playback: Plays very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey’s Audio APE, WAV/PCM, DTS, etc). Playlist Support: Build playlists from folders, use your own play lists with repeat and shuffle functions. Video Output Flexibility: Output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC). Video Up-Scaling: High quality up-scaling of DVD and any other SD video content to Full HD (1080p) or other HD resolutions. File Browser: Convenient file browser with powerful file management (copy, move, delete, rename, organize, sort). Extra Functions External NAS Support: Access files on any external storage devices (HDD, optical drive, etc) attached to the player from the local network (using SMB or FTP). Customizable User Interface: Work with media collections using cover art and icon browsing (supports Full HD graphics). Flash Applications: Extend player functionality with FlashLite applications. Internet Radio: Playback and record various Internet radio stations. IPTV: Playback and record IPTV streams Internet Browsing: View Internet web sites on your TV using the built-in web browser. Specification Processor: Sigma Designs 8672/8673 RAM: 512 MB Flash memory: 256 MB + 4 GB Connectors: HDMI 1.4, 3x USB 2.0 (2x rear, 1x front), composite, component, analog stereo outputs, optical S/PDIF, coaxial SPDIF, Ethernet 10/100/1000 Mb/s, SD card slot (front), power input, power switch (back), LED indicator (front) Internal storage: Internal HDD rack with hot swap function for SATA HDD 3.5". Media sources: external HDD (USB), external optical drive (USB), USB devices (USB flash drive, USB card reader, etc), built-in SD card reader (SD/SDHC), PC and NAS in local network (SMB, NFS, UPnP, HTTP), other Internet and local network media sources (HTTP, multicast UDP RTP) Web Browser: Opera, WebKit DLNA: DLNA (1.5 or 2.0) client support Adobe Flash: 3.1 (Lite, standalone) supported DRM options: PlayReady, Verimatrix, Secure Media. Other DRM can be added by request Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264; support for very high bitrate video (up to 50 MBit/s and higher) Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, BDMV, DVD-ISO, VIDEO_TS 3D Video Support: MVC, Side-by-side, Top/Bottom Video output modes: wide range of supported output resolutions (up to 1080p) and framerates (including 23.976p, 24p, PAL, NTSC) Video output framerate: automatic (according to the played content) and manual Audio codecs: AC3 (Dolby Digital), DTS, MPEG, AAC, LPCM, WMA, WMAPro, EAC3 (Dolby Digital Plus), Dolby True HD, DTS HD High Resolution Audio, DTS HD Master Audio, FLAC, multichannel FLAC, Ogg/Vorbis; support for very high quality audio (up to 192 kHz / 24-bit) Audio file formats: MP3, MPA, M4A, WMA, FLAC, APE (Monkey’s Audio), WV Pack, Ogg/Vorbis, WAV, AC3, AAC HD audio support: pass-through (up to 7.1 channels) and decoding (up to 7.1 channels) of Dolby TrueHD and DTS HD MA audiotracks (Blu-ray, TS, MKV), pass-through (up to 7.1 channels) of multichannel LPCM audiotracks (Blu-ray, TS, MKV), decoding (up to 7.1 channels) of FLAC audiotracks (MKV, external) Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, external SUB/IDX), PGS (Blu-ray, TS, MKV) Hardware 3D Graphics Acceleration: OpenGL support Picture file formats: JPEG, PNG, BMP, GIF Playlist file formats: M3U, PLS Photo viewer functions: slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle Audio playback functions: browse playlist, repeat, shuffle, ID3 tags, plasma TV burn-in prevention Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3/EXT4 (read-write), NTFS (read-write) Ethernet: 10/100/1000 Mb/s Wi-Fi: Internal Wi-Fi (b/g/n) module Dune Network Playback Accelerator: special optimizations ensuring best-in-class network playback performance for the Sigma Designs 864x-865x-867x platform and enabling smooth playback of any supported kind of media content via any network protocol (including NFS and SMB) even in 100 Mbit/s Ethernet networks. High-resolution Front View High-resolution Right View High-resolution Left View High-resolution Back View Source: Dune HD Base 3D Изменено 27 декабря 2012 пользователем sciagent Ссылка на комментарий Поделиться на других сайтах More sharing options...
sciagent Опубликовано: 27 декабря 2012 Автор Жалоба Рассказать Опубликовано: 27 декабря 2012 Некоторые подробности обсуждались на других ресурсах здесь и здесь на английском. Доступность в Европе - середина января 2013 согласно вот этому источнику. На русском некоторую инфу можно найти здесь и здесь. Ссылка на комментарий Поделиться на других сайтах More sharing options...
yermak Опубликовано: 27 декабря 2012 Жалоба Рассказать Опубликовано: 27 декабря 2012 Как можно обсуждать то, чего ещё ни у кого нет? С такими темами - в Болталку. Ссылка на комментарий Поделиться на других сайтах More sharing options...
sciagent Опубликовано: 27 декабря 2012 Автор Жалоба Рассказать Опубликовано: 27 декабря 2012 Цитата Как можно обсуждать то, чего ещё ни у кого нет? Позвольте пользоваться столь умилительной фразой. Обещаю всегда упоминать авторство: yermak, forum.kartina.tv По существу: вот небольшой видеообзор новой 3D линейки от Dune HD c IFA 2012. Там можно увидеть выставочный образец Dune HD Base 3D. Ссылка на комментарий Поделиться на других сайтах More sharing options...
ottoman Опубликовано: 27 декабря 2012 Жалоба Рассказать Опубликовано: 27 декабря 2012 (изменено) На первый взгляд для меня те же недостатки как и у предыдущей модели: - наличие вентилятора (знаю что надо отводить тепло от HDD) - нет поддержки DLNA server - нет второго HDMI - не видно поддержки BD-ISO - цены пока не знаю, но видимо будет не дешевле Duo Изменено 27 декабря 2012 пользователем ottoman Ссылка на комментарий Поделиться на других сайтах More sharing options...
yermak Опубликовано: 27 декабря 2012 Жалоба Рассказать Опубликовано: 27 декабря 2012 (изменено) sciagent писал: Позвольте пользоваться столь умилительной фразой. Обещаю всегда упоминать авторство: yermak, forum.kartina.tv Да ради бога! Пользуйтесь на здоровье. Только с какого бока эта радость относится к данной теме? Хотите обсудить -есть соответствующие темы: Альтернативные способы просмотра и Болталка. А если Вам нужна "Помощь по настройке и решение технических проблем" для данного аппарата, то немного рановато. Изменено 28 декабря 2012 пользователем yermak Ссылка на комментарий Поделиться на других сайтах More sharing options...
sciagent Опубликовано: 27 декабря 2012 Автор Жалоба Рассказать Опубликовано: 27 декабря 2012 ottoman писал: На первый взгляд ... Всё верно. Первый и третий пункты - очевидны и от них некуда деться. Ну, разве что отключать вентилятор в случае установки малогреющихся винтов. И использовать HDMI хаб/сплиттер, это зависит от того, какая именно необходимость во втором HDMI выходе. С DLNA сервером что-то никак не разродятся они (а зря). В техданных одного из клонов говорится о поддержке стандартов 1.5 или 2.0. Но у производителя нынче указан именно клиент. Посмотрим, ведь это дело - программное, и в релизе ещё может измениться. Поддержка BD ISO обещалась, но нынче не понятно как она будет реализована, особенно ввиду Canavia и отсутствующего BD привода. Кстати, говоря о клонах и ребрендинге - надеюсь, что Картина.ТВ выпустит вскоре свою версию под своим брендом и/или со своей прошивкой. Посмотрим, что будет уметь релиз, и сколько он будет стоить. Ссылка на комментарий Поделиться на других сайтах More sharing options...
ottoman Опубликовано: 28 декабря 2012 Жалоба Рассказать Опубликовано: 28 декабря 2012 sciagent писал: ottoman писал: На первый взгляд ... Всё верно. Первый и третий пункты - очевидны и от них некуда деться. Ну, разве что отключать вентилятор в случае установки малогреющихся винтов. И использовать HDMI хаб/сплиттер, это зависит от того, какая именно необходимость во втором HDMI выходе. С DLNA сервером что-то никак не разродятся они (а зря). В техданных одного из клонов говорится о поддержке стандартов 1.5 или 2.0. Но у производителя нынче указан именно клиент. Посмотрим, ведь это дело - программное, и в релизе ещё может измениться. Поддержка BD ISO обещалась, но нынче не понятно как она будет реализована, особенно ввиду Canavia и отсутствующего BD привода. Кстати, говоря о клонах и ребрендинге - надеюсь, что Картина.ТВ выпустит вскоре свою версию под своим брендом и/или со своей прошивкой. Посмотрим, что будет уметь релиз, и сколько он будет стоить. У меня проложен HDMI кабель в смежную комнату и я не собираюсь использовать сплиттер из принципа (отдельная коробка со своим или USB питанием). Приличные BD плеера идут с 2-мя HDMI. По мне так лучше алюминиевый корпус, можно даже чуть больших размеров, но без вентилятора. Винты подобрать не проблема. Ссылка на комментарий Поделиться на других сайтах More sharing options...
sciagent Опубликовано: 28 декабря 2012 Автор Жалоба Рассказать Опубликовано: 28 декабря 2012 (изменено) Такой вариант использования - не сложный. Хуже, когда необходимо разную аппаратуру подключать. Однако про "приличные" плейера... Мне такие не были известны. Поискал и нашёл в некотором роде подтверждение. falkenbakh с forum.ixbt.com, в ответ на вопрос "Какие из вышеперечисленных плееров имеют полноценный второй выход HDMI, можно 1.3?", утверждает следующее: " Таких нет. Все плееры у которых на борту есть два hdmi выхода сделаны по одинаковой схеме - основной выход работает через специализированный видеопроцессор, со всеми возможностями обработки сигнала этим процессором, второй работает через центральный процессор. Поэтому в вашем случае на основной выход нужно будет ставить hdmi сплиттер для разветвления видеосигнала на телевизор и проектор. Такие устройства стоят до $100 и довольно неплохо себя зарекомендовали. При выборе сплиттера важно обратить внимание на то, чтобы он был версии 1.4. Это что касается видео. Для аудио будете использовать второй выход напрямую в ресивер и будет вам счастье. Есть ряд плееров, имеющих на борту два выхода hdmi от таких производителей как ОРРО (OPPO BDP-93/95), ASUS (ASUS O! Play BDS-700/500), Pioneer (Pioneer BDP-450). Выбирать вам по своим предпочтениям и кошельку. " У Вас есть примеры плейеров, которые имеют полноценные HDMI выходы? В своё время, проанализировав возможные варианты по переносу HD видеосигнала на приличное расстояние в другие комнаты, принял решение поставить под/за каждым телевизором по медиаплейеру. Когда появился Kartina HD 301 - оказалось, что это - гораздо более удобное и, беря в учёт функциональность, весьма конкурентноспособное по цене решение. Но, конечно, если надо передать видео лишь через стену, и необходимость в одновремённом использовании отсутствует, то кабель будет, пожалуй, лучшим решением. Моя "проблема" в том, что, попробовав смотреть Картина.ТВ на нескольких плейерах, убедился, что плейеры от Dune HD - лучшие для этой цели (никаких проблем с переключением каналов, отсутствие явных глюков, простота использования). Они уступают в возможностях некоторым плейерам других известных брендов, но предпочитаемы членами моей семьи (включая весьма пожилых), которые и являются их основными пользователями. Поэтому под главный телевизор мне пришлось поставить Dune HD Smart D1, а у него нет HDMI 1.4. Вот и жду версию Дюны, которая будет иметь такой интерфейс и вмещать 3,5-дюймовые харды. Изменено 28 декабря 2012 пользователем sciagent Ссылка на комментарий Поделиться на других сайтах More sharing options...
ottoman Опубликовано: 28 декабря 2012 Жалоба Рассказать Опубликовано: 28 декабря 2012 sciagent писал: Такой вариант использования - не сложный. Хуже, когда необходимо разную аппаратуру подключать. Однако про "приличные" плейера... Мне такие не были известны. Поискал и нашёл в некотором роде подтверждение. falkenbakh с forum.ixbt.com, в ответ на вопрос "Какие из вышеперечисленных плееров имеют полноценный второй выход HDMI, можно 1.3?", утверждает следующее: " Таких нет. Все плееры у которых на борту есть два hdmi выхода сделаны по одинаковой схеме - основной выход работает через специализированный видеопроцессор, со всеми возможностями обработки сигнала этим процессором, второй работает через центральный процессор. Поэтому в вашем случае на основной выход нужно будет ставить hdmi сплиттер для разветвления видеосигнала на телевизор и проектор. Такие устройства стоят до $100 и довольно неплохо себя зарекомендовали. При выборе сплиттера важно обратить внимание на то, чтобы он был версии 1.4. Это что касается видео. Для аудио будете использовать второй выход напрямую в ресивер и будет вам счастье. Есть ряд плееров, имеющих на борту два выхода hdmi от таких производителей как ОРРО (OPPO BDP-93/95), ASUS (ASUS O! Play BDS-700/500), Pioneer (Pioneer BDP-450). Выбирать вам по своим предпочтениям и кошельку. " У Вас есть примеры плейеров, которые имеют полноценные HDMI выходы? В своё время, проанализировав возможные варианты по переносу HD видеосигнала на приличное расстояние в другие комнаты, принял решение поставить под/за каждым телевизором по медиаплейеру. Когда появился Kartina HD 301 - оказалось, что это - гораздо более удобное и, беря в учёт функциональность, весьма конкурентноспособное по цене решение. Но, конечно, если надо передать видео лишь через стену, и необходимость в одновремённом использовании отсутствует, то кабель будет, пожалуй, лучшим решением. Моя "проблема" в том, что, попробовав смотреть Картина.ТВ на нескольких плейерах, убедился, что плейеры от Dune HD - лучшие для этой цели (никаких проблем с переключением каналов, отсутствие явных глюков, простота использования). Они уступают в возможностях некоторым плейерам других известных брендов, но предпочитаемы членами моей семьи (включая весьма пожилых), которые и являются их основными пользователями. Поэтому под главный телевизор мне пришлось поставить Dune HD Smart D1, а у него нет HDMI 1.4. Вот и жду версию Дюны, которая будет иметь такой интерфейс и вмещать 3,5-дюймовые харды. Хорошая работа, но пардон мне это все было известно, тем более, что мне не нужен полноценный второй HDMI на SAMSUNG BD-D6500. Если ставить второй плеер, то я опять же из принципа не хочу его использовать по WLAN. Ссылка на комментарий Поделиться на других сайтах More sharing options...
sciagent Опубликовано: 11 января 2013 Автор Жалоба Рассказать Опубликовано: 11 января 2013 Итак, согласно официальному источнику, начались поставки Dune HD Base 3D, TV-102 и TV-303D. Значит, дилеры начнут продавать эти медиаплейеры в обозримом будущем. Лифлет уже существует (PDF формат). Ссылка на комментарий Поделиться на других сайтах More sharing options...
ITDLplus Опубликовано: 11 января 2013 Жалоба Рассказать Опубликовано: 11 января 2013 sciagent писал: Итак, согласно официальному источнику, начались поставки Dune HD Base 3D, TV-102 и TV-303D. Значит, дилеры начнут продавать эти медиаплейеры в обозримом будущем. Лифлет уже существует (PDF формат). Совершенно верно, поставки начались, в Германии будет в конце января Ссылка на комментарий Поделиться на других сайтах More sharing options...
juriky Опубликовано: 23 января 2013 Жалоба Рассказать Опубликовано: 23 января 2013 (изменено) Существенные минусы: -в Dune HD BASE 3D отсутствует возможность подключить внутреннюю флешку (нет разъема). -меню на Blu-Ray не показывает полностью, как впрочем и раньше на других. -отсутствует торрент-клиент. Изменено 14 февраля 2013 пользователем juriky Ссылка на комментарий Поделиться на других сайтах More sharing options...
sciagent Опубликовано: 5 марта 2013 Автор Жалоба Рассказать Опубликовано: 5 марта 2013 Создаётся впечатление, что Dune HD TV-303D быстрее, чем Base 3D, покоряет сердца дистрибюторов Kartina.TV - но пока ещё не самой Картины. Пока что приведу ссылки на парочку веток на форумах, где обсуждается сабж этой ветки на русском и английском. Модель весьма неоднозначная, судя по отзывам, хотя и одна из лучших на рынке. Тем не менее былые топовые модели, начиная с серии Dune HD Smart всё ещё продолжают быть актуальным выбором. Ссылка на комментарий Поделиться на других сайтах More sharing options...
Xisaleir Опубликовано: 11 мая 2015 Жалоба Рассказать Опубликовано: 11 мая 2015 Кто нибудь сталкивался с проблемой воспроизведения картинки в m2ts файлах? Выборочно, плейер полностью поддерживает одни файлы и не воспроизводит видео с других подобных из одного сборника видео клипов. Не думаю, что там так уж сильно параметры разнятся. Звук идёт везде. Проблема с самим плейером или где-то в дюновских в настройках? Ссылка на комментарий Поделиться на других сайтах More sharing options...
alexsolo Опубликовано: 12 мая 2015 Жалоба Рассказать Опубликовано: 12 мая 2015 Пример видео имеется? Ссылка на комментарий Поделиться на других сайтах More sharing options...
Xisaleir Опубликовано: 16 мая 2015 Жалоба Рассказать Опубликовано: 16 мая 2015 alexsolo, какой у вас email? Ссылка на комментарий Поделиться на других сайтах More sharing options...
alexsolo Опубликовано: 16 мая 2015 Жалоба Рассказать Опубликовано: 16 мая 2015 Вы линк дайте в личку или сюда. Ссылка на комментарий Поделиться на других сайтах More sharing options...
Xisaleir Опубликовано: 16 мая 2015 Жалоба Рассказать Опубликовано: 16 мая 2015 https://drive.google.com/folder/d/0B_8ogn5qNgjpS1hDeGUwTVd4UWs/edit Ссылка на комментарий Поделиться на других сайтах More sharing options...
alexsolo Опубликовано: 16 мая 2015 Жалоба Рассказать Опубликовано: 16 мая 2015 Ага, звук идет - видео нет, сейчас подсунем в раздет бэта-теста dune. Ссылка на комментарий Поделиться на других сайтах More sharing options...
Xisaleir Опубликовано: 16 мая 2015 Жалоба Рассказать Опубликовано: 16 мая 2015 Скачал себе это видео на LG G3, раз файл уже находится в моём облаке, всё работает отлично - и звук и видео. Ссылка на комментарий Поделиться на других сайтах More sharing options...
Berimur Опубликовано: 4 июня 2015 Жалоба Рассказать Опубликовано: 4 июня 2015 сегодня установил фирменную прошивку от dune-. скачал ютубовский плагин . активировал картину TV- всё работает. тема с ютубом почему то закрыта. новую тему открывать не охота. я тут редко. может уже и не актуально. тогда извеняюсь Ссылка на комментарий Поделиться на других сайтах More sharing options...
alexsolo Опубликовано: 4 июня 2015 Жалоба Рассказать Опубликовано: 4 июня 2015 Откуда скачали то плагин? Ссылка на комментарий Поделиться на других сайтах More sharing options...
Berimur Опубликовано: 4 июня 2015 Жалоба Рассказать Опубликовано: 4 июня 2015 http://forum.hdtv.ru/ Ссылка на комментарий Поделиться на других сайтах More sharing options...
alexsolo Опубликовано: 5 июня 2015 Жалоба Рассказать Опубликовано: 5 июня 2015 Да, Дюна втихую свернула тему с youtube, соответсвенно на картиновских прошивках пользователи в пролете. Ссылка на комментарий Поделиться на других сайтах More sharing options...
