Как я улучшил соединение с роутером Linksys
odenor
Все время появлялась надпись " Timeout....."
Танцы с бубном не помагали Интернет идет в принципе хорошо Канал 17 МБИТ
Роутер Linksys WRT160 NL 300 mbit 4 компа в доме
Поменял следующие уставки в роутере
После этого Картина идет вообще без прерываний
Буду рад если это поможет кому то
1. Open a web browser (such as Internet Explorer or Netscape)
2. When the browser opens, go to the "Address" bar and input the IP address of the Wireless Router (The default IP Address is 192.168.1.1).
3. A "User Name" and "Password" prompt will appear, leave the "User Name" field blank and input the Wireless Routers password (The default password of a Linksys Router is admin) into the "Password" field.
4. After the "Setup" Page loads, click on the Wireless tab, then click on the Advanced Wireless Settings sub tab.
Adjusting the "RTS Threshold" can help alleviate Packet loss. Set the "RTS Threshold" to 2304. After changing the value click on the Save Settings button on the "Advanced Wireless Settings" screen, then a page will appear prompting that the settings were successful, and when that page appears, click on the Continue button .
Adjusting the "Beacon Interval" adjusting the "Beacon Interval" to 50. After changing the value click on the Save Settings button on the "Advanced Wireless Settings" screen, then a page will appear prompting that the settings were successful, and when that page appears, click on the Continue button .
Adjusting the "Fragmentation Threshold" Try adjusting the "Fragmentation Threshold" to 2304. After changing the value click on the Save Settings button on the "Advanced Wireless Settings" screen, then a page will appear prompting that the settings were successful, and when that page appears, click on the Continue button .
Также поменял вручную на канал 11
Изменено пользователем odenor
  schner-media писал:
a mozhno po-russki?
1. Откройте web-браузер (такой как Internet Explorer или Netscape)
2. Когда браузер открывается, пойдите в бар "Адреса" и введите IP адрес Беспроводного Маршрутизатора (Адрес IP по умолчанию 192.168.1.1).
3. "Имя пользователя" и быстрый "Пароль" появятся, оставят бланк области "Имени пользователя" и введут Беспроводный пароль Маршрутизаторов (пароль по умолчанию Маршрутизатора Linksys - admin) в область "Пароля".
4. После того, как Страница "Установки" загружает, нажать на Беспроводный счет, затем нажать на Продвинутые Беспроводные Параметры настройки sub счет.
Наладка "Порога RTS" может помочь облегчить потерю Пакета. Установите "Порог RTS" к 2304. После изменения ценности нажимают на кнопку Save Settings на экране "Advanced Wireless Settings", затем страница будет казаться вызывающей, что параметры настройки были успешны, и когда та страница появляется, нажмите на кнопку Continue.
Наладка "Интервала Маяка" наладка "Интервала Маяка" к 50. После изменения ценности нажимают на кнопку Save Settings на экране "Advanced Wireless Settings", затем страница будет казаться вызывающей, что параметры настройки были успешны, и когда та страница появляется, нажмите на кнопку Continue.
Наладка "Пороговой Попытки" Фрагментации, приспосабливающей "Порог Фрагментации" к 2304. После изменения ценности нажимают на кнопку Save Settings на экране "Advanced Wireless Settings", затем страница будет казаться вызывающей, что параметры настройки были успешны, и когда та страница появляется, нажмите на кнопку Continue.
p.sНо лучше писать по-русски ;)
Теперь, кто понял что Syrin сдесь описал, может сделал бы похожее описание для Fritz-Box-a, а то я ничерта непонял.
  pawlodar писал:
Я просто статью перевел "на translate"и всего ;)
  pawlodar писал:
Я специально не писал по английски так просто скопировал с сайта.Но у вас в роутере названия то на английском .Посему.. можно понять что надо изменить
Идите в Advanced Wireless Settings
поменяйте RTS Threshold" to 2304
поменяйте "Beacon Interval" to 50
поменяйте "Fragmentation Threshold" to 2304
канал поствьте на 11
нажмите SAVE (сохранить)
